bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
I just test ran the Mamba-X/1410-3800Kv combo. Stock gearing, punch control at 25%, slipper medium tight. 2s is just way to slow for me. Totally unimpressed. Would definitely need to change the gearing if I were to run 2s as my go to. After 20 minutes of 2s I swapped in a storage charged 3s battery. Much more to my liking. Still not super fast but much better than the 2s. I still might change the gearing with 3s and I will definitely run 3s with this setup. Spur held up fine. I also put my Proline Trenchers on for the runs. Nice tires. Did have one come off, Thankfully I had an extra wheel nut. I'm afraid to crank them too tight because I broke one already. But if you don't you should check them after every battery, Those nuts come loose.
Question regarding the ESC fan. Is is supposed to run all the time? I don't think mine ever came on. My SW4 ESC had a wire that went to the Aux channels specifically for the fan and it ran 24/7. The Mamba has a separate Aux wire but it is programmable for different functions and not used for the fan (so I think.)
