- Thread starter
- #21
It was a triple pack of shims I bought of three variating thicknesses I think I got 10 of each and pretty sure they were kyosho too . What ever size the front bearing internal diameter is that’s the size you buy , I think typhons are 6mm so you would buy 6x8 shims . I do mine with the shaft through the hun and the wheel off and Add it then and tighten the wheel nut on on my kraton and the typhon I do it the same but shim until I can push the hex pin in without any real pressure so as not to squeeze the bearingsI've got the HR bell crank installed on my OC4s and there is definitely STILL a small amount of upwards movement at the link on the bell crank where it has a steel collar going through it. I wonder if those shims would work on the HR bell crank too? Im going to order and find out. x
When you shim the hub bearings behind the wheel hex, are you using the same size shims as the steering slop? Shumaker 5x7x04?
