chrisexv6
A pet project during the off-season will be to go over the diffs in both our 6S trucks. They are holding up OK right now, a few broken pins that Ive replaced but not really a lot to complain about.
Was thinking - is it better to just replace with EXB diffs (assuming Arrma fixes them), or do I modify/upgrade the V4 diffs?
I was looking at - aluminum cups all around (son's Kraton already has 3, my Outcast only has 1), shim them internally along with shimming the pinion, upgrade to drill blank pins and M2C outdrives for better durability.
Versus EXB diffs that presumably already have better outdrives (larger diameter), heavier duty pins and gears, but still plastic cups. EXB would cost more, but hopefully hold up better in the long run, maybe?
We're just bashers, BTW....no racing, so the LSD isnt a necessity but if it helps keep everything together Ill go with it.
Thanks in advance.
-Chris
Thanks in advance.
-Chris
