Fixed my none centering steering issue
Cater4anytink
Birmingham uk
I've finally fixed my wheels not returning to center problem. I found a you tube video by kasper becker.
I spent so much time trying to find the cause like taking my servo apart and ordering a new one, ajusting servo saver,and loosening quiet a lot of the front end. Turns out if you remove wheels you have two red knuckles if you loosen them it fixes the problem. How did we get by before internet with the many great forums and youtube. Here's the link.
I would suggest you spray some dry lube and or Powdered graphite behind those Red kuckles. And then I thnk the rule of thumb is to tighten them snug, and back off 1/4 turn. you don't want the Hub assembly to have any play in it, but you also don't want to bind the ball joint.
