- Kraton 8S
- Mojave
- Notorious
- Senton 6s
- Talion
So my last outing at the bmx track with the Typhon resulted in a really bent chassis/rear diff housing/and rear front suspension ( I call it a C block ) , and bent the HR rear chassis brace . Decided to just go with a new chassis from Jennys to make it like new again ( won't be going to the bmx track anytime soon ) as it is winter . I know the M2C chassis is the way to go , but I will put that into my Talion , going to not send the Typhon as much as I will do with the Talion .
The Typhon is truggified for now , will use it to play in the snow/etc . So just as people talk about stripped scews , I only had to do that once to learn my lesson ( on the Talion ) , had no problem tonight changing over the chassis , I used my heat gun and warmed up the motor mount screws/grub screws on diff outdrive/sliding motor mount . Came right off . Took about 3 hours ,
Put on backflips on the Talion to , can't wait to try them out again .
