BattleShrink
- Senton 6s
- 4x4-Mega
So the chassis flex has totally destroyed the rear end of my stock body. If you don't want to keep buying bodies or make a tower-to-tower brace or stop jumping and doing backflips, then I have the mod for you! All you need is a body with the area around the rear body holes disintegrated, a small zip tie, and two rubber bands.
Remove the two rear rubber clip retainers, you don't need them anymore. Thread the zip-tie through the existing holes, and adjust the zip-tie diameter and the rubber bands for a little tension, you don't need a lot to hold it in place.
If your rear end is at a different level of disintegration than mine you may have clearance issues, I don't remember what it looked like. Now the chassis and the body can both flex when you have horrible lawn-dart crashes, catastrophic over-rotating backflips directly into the wing, and other general shenanigans. Front end remains the same.
