Limitless Flopack RC - 1/7 scale center brace
While I’m not sure of that brace why not get THIS one? It fits you just need either washers to fill the gap or a certain size spacer. I went with spacers since it looks cleaner. Plus it’s scorched so you know the quality is top notch.
Does that work with PPS?
Yup
I tried submitting through their website but the "submit" button doesn't work for some reason so I'm trying a much better resource AF.
Does anyone know if the Arrma Brace from Flopack fits with a PPS mount?
https://www.flopackrc.com/product-page/1-7-arrma-brace-the-brace
Yeah I doubt that since the PPS has a pretty big top cap piece on it.
Man that looks like a sketchy product with the 3d printed bearing holders. There is no way I am going to trust a 3d printed part to hold all the forces applied to the spool assembly.
It looks like you replaced the top plate. Where is your front body post?
I'm running the original F1 Style Shell and need that post
I'm thinking this might be an issue with the Flopack one too?
I’m running GT so I don’t use that mount. There is a hole for it but scorched says some fitting might be required.
