Flysky gt3c
Rcdupont
  2. Talion
Since I started using the gt3C with my Senton I'm experiencing some issues. Every time after I drive it backwards it's like it's willing to drive more backwards and you can hear the dogbones actually clicking. How can I solve it? I've tried to recalibrate but doesn't help....
lonee
Germany
  1. BigRock
does the GT3C have ABS?
Do you checked the throttle endpoints in the transceiver before you made teaching the ESC?
The "clicking" sounds like cogging. I think that you're Senton will have the normal BLX setup. Therefore you will have cogging, because that system is sensorless.
Anyway, Workaround:
1. Reset transmitter and ESC.
2. Check and adjust throttle endpoints to 100%.
3. switch ABS to off.
4. teach you´re ESC with the three positions of you´re throttle chanel.
At least all should be OK
A litte cogging will keep in you're system..
