jondilly1974
Speed running apprentice, motor Slayer 🤘
- Toledo, OH
- Granite
- Infraction
- Kraton 6s
- Kraton EXB
- Senton 3s
- Typhon 6s
- Typhon 3s
Dear Mr Flysky,
My name is Jon and I like to speed run my RC cars. I really like your Noble NB4 radio. It’s super cool. But one thing it’s missing is profile settings that I can change on the fly.
You see, when you’re speed running, you have to drive your car to the start line, turn it around, then make a super fast speed run to the other end of the road, turn around again, and drive back to yourself so you can check your speed.
The problem is, in order to turn around at the start and finish lines, you need to be able to turn easily. However, when making the high speed pass, you don’t need to be able to turn that much and the extra sensitive steering causes crashes.
To fix this issue, we have to turn down the steering rate just before taking off on the speed pass. Then remember to turn it back up to turn around at the finish. This is a cumbersome process today.
The other common feature that you made so well for us speed run guys is the CH Speed feature. We love that you made this as we can ensure a nice clean even throttle pull every single pass. However this setting makes turning around very difficult as forward throttle input is basically ignored at low levels. These low levels of forward throttle are generally used to turn around at the start and finish.
So again we turn this feature off until ready to make the speed pass, and again turn it off before turning around at the finish.
Others might have various features they like. In the end, if we could have multiple profiles for each model, then we could switch quickly at the start and finish lines, saving us precious time.
I would love to see these profiles either on a quick touch button on the home screen or we could also use one of the extra channel physical buttons to modulate this setting.
I hope this info is clear enough to give you what you need to make your radio even better.
Your friend,
JonDilly1974
Your friend,
JonDilly1974
