Kraton Forward or Reverse ESC setting for XLX2/2028-800kv combo?
Engineer
Ohio
  1. Voltage
Trying to get my ESC setup beforehand while completing my KEXB build. Does anybody know how the motor rotation should be set on the ESC for the XLX2/2028 combo? Thanks!
I have a Limitless with an XLX2 and a Castle 1717 (not exactly the same but close). In the stock location it's reversed. I did this on the ESC not the radio. You will need to calibrate with it in not-reversed, then set it up on the ESC.
with a spektrum receiver i used normal but when using futaba receiver i had to change to reverse on the transmitter i believe. on my 6s spektrum receiver i had to reverse motor direction with mamba x and 1515 motor
I've seen notes like this before. For some reason Futaba does it backwards.
Some engineer did that by accident or on purpose years ago and Futaba decided to roll with it. There is no advantage that I can see to having the signal backwards.
