Figured I would do a proper build log on my kraton6s.
I got my kraton6s BNIB on 30 March 2020. I basically walked into my LHS and grabbed it off the shelf. Ran it stock uneventful for a good amount of packs. I was working on my granite at the time so this was my basher and I kept it running.
After the first run
Once I finished my granite build I turned to my kraton6s. Around this time mail delivery started getting really backed up so parts were trickling in.
The first things I had on-hand to install were:
Hot racing bulkheads f/r
Arrma metal diff cases f/c/r
PPS adjustable motor mount
Hot racing steering servo mount
Hot racing fixed servo link
Hot racing aluminum steering blocks and rear hubs
Hot racing aluminum steering post and servo saver
Got some tips that the aluminum braces should have been on the top of list from the get go so I ordered those up next. Because I was planning my infraction build at the same time I ordered parts for that as well and I think that's what added to my holdup. I mounted my motor and esc at the same time I installed the braces.
It took a while for some other parts to come in. The next one delivered were my hot racing center diff sections. I was waiting for my pps center section so I grabbed the hr stuff as a fill in.
Waiting on parts I forgot about the build randomly. One day I was looking at it and noticed my shocks were canted a bit. Turns out there's some slop in the stock pivot balls. I 3D printed some half bushings out of TPU and it got all that slop out.
Then my pps center section items showed up. Because I wanted to retain the kraton6s roll cage support I kept the HR center section and used the pps motor mount and pps front diff carrier. Looks nice too with the color offset.
Time to start wiring once the last of the bits arrived. Yeah racing aluminum tornado fans for the yeah racing heatsink.
Then soldered the esc and motor. Most people use bullets (nothing wrong with that) but my drone experience keeps me soldering direct to the motors.
And getting all back in.
And here's the fans wired to the esc fan port.
A couple of notes on the last image. I could only mount the fans in the position they are in due to the motor really being mountable in the position it is in. I could not rotate the motor without the phase leads touching something it shouldn't. Then the heatsink got close to the roll cage support bracket. It was interesting to say the least. You might also notice that I have a DS3225 servo on there. I tested three other servos and settled on the DS3225 because this version was the one that was 7.4V capable. The 6V versions just didn't seem to really be worth it (even at $30ish for each).
It's practically done now. I just need to figure out which wheel to use for the maiden.
After the first run
