Crystal ball not working. Need details.I was wondering if this will fit in my nouturios 6s BLX how to replace my stock motor I was wondering if this was better and what do I need to go with it?
? opps forgot to post im at workCrystal ball not working. Need details.
Might be okay for racing the Typhon or Senton 6s too. I think most of the 1/8 e buggy guys use 4068 cans.I run that motor in my 1/10 scale Rock Rey. Way too small for your Notorious. It would be good in the Arrma 4S trucks though. Even th 3S trucks.
4s on punch 9 is crazy enough for meYes it will fit right in, however that motor is limited to 4s.
As @bicketybam mentioned it is a little smaller than the stock motor and is meant for 1/8 buggy, short course trucks and other vehicles up to 9lbs the Notorious is 11lbs 9oz stock without a battery.4s on punch 9 is crazy enough for me
Ok thanksAs @bicketybam mentioned it is a little smaller than the stock motor and is meant for 1/8 buggy, short course trucks and other vehicles up to 9lbs the Notorious is 11lbs 9oz stock without a battery.
Can I still use the stock. 185 ESCAs @bicketybam mentioned it is a little smaller than the stock motor and is meant for 1/8 buggy, short course trucks and other vehicles up to 9lbs the Notorious is 11lbs 9oz stock without a battery.
YupCan I still use the stock. 185 ESC
I have a senton 4x4 3s BLX. Stock will it go in there and use the stock ESC???
It will fit in there but I am pretty sure that the esc can't handle it, the 4s esc might be able to and the 6s definitely will.I have a senton 4x4 3s BLX. Stock will it go in there and use the stock ESC???
What would you put in to replace stock ESCIt will fit in there but I am pretty sure that the esc can't handle it, the 4s esc might be able to and the 6s definitely will.
In the Senton probably a blx 6s esc.What would you put in to replace stock ESC
Or, if you have a bit more cash, a Castle Mamba Monster X. Then you could run it sensored...What would you put in to replace stock ESC
Or this.Or, if you have a bit more cash, a Castle Mamba Monster X. Then you could run it sensored...
Even if you run it sensorless, the Castle Mamba ESCs are so much smoother than the BLX ESCs...
