Kraton, Outcast, Notorious, and Talion all use spiral cut gears, the Typhon, Senton, Infraction and Limitless use straight cut gears and they are a different ratio.I have a question. Are the front and rear diffs in the arrma 6s line up the same? If not, could you use the typon front/ rear diffs in a talion?
Me personally I wouldn’t there’s a slight angle to the gears that I guess makes it strongerI have a question. Are the front and rear diffs in the arrma 6s line up the same? If not, could you use the typon front/ rear diffs in a talion?
2 year old thread and he hasn't been on since September 2020.Me personally I wouldn’t there’s a slight angle to the gears that I guess makes it stronger
