Hey guys . I was wondering how important it is to have grease inside the gearbox housing in the kraton front and rear .. and if it would be ok to use thick diff fluid ?
Is it even worth putting on then? Also has anyone noticed a difference with using grease and without?Less the better. The first time you go 1/4 throttle it all flicks off the ring and pinion anyway and messes up the inside of your diff case..
I say it’s always a good idea, while yes, most of it flings to your diff case... while initially running the ring and pinions there may be tiny shavings that come off of new or even newly meshed together used ones. And the grease helps , we’ll... fling it to the case to stick and not just free to move about in your gears... or at least that’s an idea of what might happen?Is it even worth putting on then? Also has anyone noticed a difference with using grease and without?
