sevin7
Why were the shims there to begin with? Did they come pre-installed or did you add them?
They come pre-installed to set camber.Why were the shims there to begin with? Did they come pre-installed or did you add them?
Haha same happened to mePic of the right side, took it apart thinking something must be bent, everything seems fine and axles are straight. Would be nice to solve this before the RPM arms go on there, or if the RPM arms are the solution ? Less Flex ?
Try adding bump stops using fuel tubing over the shock shafts to prevent the arms from over extending during hard landings. A big roll of 1/8” tubing from Home Depot is a few bucks and will last a lifetime in RC purposes.I've had this problem since I got the Outcast exb.. replaced over 10 broken drive cups!! Replaced steering knuckles(HR),differential housing and cover(HR),the differential, hubs and dog bones.. I've replaced the the drive cups with m2c racing ones and that stopped the breaking but they still pop out... this only happens in the front.. so damn frustrated!!
Also replaced the entire steering setup, servo horn ,steering rack, servo save.
