Kingofanna
- Points
- 88
Hey, first post in the forum. I've had my Kraton for about 5 months and it's awesome. At one point I had to replace the housing for my front diff because I cracked it before I got a front bumper. Over time, taking the diff housing apart, I've noticed that I can't tighter the screws down and they spin in the hole (stripped). Now when I drive on 6s the power eventually loosens the halves a little causing the input drive to not make good contact with the spur. I'm currently trying a little loctite in the hole and some plumbers tape to try to tighten them down. Also I cranked the sway bar down as tight as possible to hold it together. I know I should just get a new housing but what is to prevent it from happening again? I don't use my drill on plastic parts. Also, in a related isssue, I'm not wild about the brace for the tbone bumper attaching to the plastic diff housing. I think the force from that may have stripped the holes for the top screws on the housing.
