While I was trying to adjust the slipper clutch I heard a breaking sound then everything seperated and this broke in half. Is this fixable at all or no?
I also tried glueing didn't work. These break too easily for 4s.I did that to i try gluing and pressing it on but i had to get a new one
When making adjustments to the slipper aren't you supposed to screw it at it's max and the unscrew the needed amount? I tried that and this happened maybe it was already overtightened when I bought it out of brand new kraton 4s at jennyrc. I guess just bad luck as always.Time for a new hub.. you over tightened the screw causing it to break, user error unfortunately...
Oh no, that’s a sure fire way to break the slipper hub exactly like you did. I tighten it until I feel the least bit of resistance, then I tighten it a tiny bit more and test it. If it’s too loose, I will tighten it in very small increments, like a quarter turn, until I get it just right. I have six, 3 and 4s cars so I’ve learned to adjust the slippers very carefully since I do it so much. They work very well when set up right.When making adjustments to the slipper aren't you supposed to screw it at it's max and the unscrew the needed amount? I tried that and this happened maybe it was already overtightened when I bought it out of brand new kraton 4s at jennyrc. I guess just bad luck as always.
