68mm from inside of end linksView attachment 104974
I'm curious what are the lengths in mm, of your front turnbuckles? What distance are they from factory? Any help would be appreciated...
Hey I do what I can. Glad to help. Looking forward to the vids ??Hey man, you ALWAYS come through! I was expecting you to respond. I'm going to start getting some vids of me out running!
Trying to catch up with you!
I'm curious about one other thing... on the servo horn, there are three different holes to select. Should you choose the hole that makes it the most square?Hey I do what I can. Glad to help. Looking forward to the vids ??
I think the further notches will put more leverage/load on the servo but it will also turn the wheels further with the same servo movement than on an inner notch. My instinct would be the center notch to balance it.I'm curious about one other thing... on the servo horn, there are three different holes to select. Should you choose the hole that makes it the most square?
Definitely helped square things, AND the horn is more centered on the center of the servo...was a few degrees in front of center.I think the further notches will put more leverage/load on the servo but it will also turn the wheels further with the same servo movement than on an inner notch. My instinct would be the center notch to balance it.
What driveshafts do you have there?Definitely helped square things, AND the horn is more centered on the center of the servo...was a few degrees in front of center.
I'm learning these cars are REALLY fue those into intricacies and problem solving!
https://scorchedparts.co.uk/products/copy-of-arrma-titanium-centre-drive-shaft-kraton-talionWhat driveshafts do you have there?
Do they have stronger outdrive cups...diff gears?What driveshafts do you have there?
I believe M2C is going to or already has outdrive cups but my fear is the V1 sun gears won’t take much more power. The V2 that I’ve seen pictured here looks more beefy. Time will tell.https://scorchedparts.co.uk/products/copy-of-arrma-titanium-centre-drive-shaft-kraton-talion
