Fury 2WD Rear A-Arms on the Gorgon
FJSPEED
RC Showcase: 2
Hunterdon, NJ
  1. Felony
  2. Fireteam
  3. Infraction
  4. Kraton 8S
  5. Outcast 6s
  6. Typhon 6s
  7. Typhon Grom
  8. Vendetta
I found that the Fury 2WD rear a-arms are a direct fit on the Gorgon (also same length) and have an additional support bridging the outer ends as well as connecting points for a anti sway bar and two screw holes for dirt guards.
Gorgon rear a-arm
Fury 2WD rear a-arm
Gorgon rear a-arm
Fury 2WD rear a-arm
I could be wrong, but, I thought the only difference between the Fury and Gorgon was the chassis, body, wheels and tires.
When the Fury and Vorteks were refreshed, they added at least a couple features. The beefed/modified rear arms and rear hub/bearing carrier has 2 adjustment holes for the upper link. The rear arms, rear carriers and drive shafts are interchangeable with the 3s 4x4 line with narrow arms (Vorteks, Granite.) I will add the arms on my 4x4 Vorteks to have the added strength. I would not be surprised to see these already on the new Vorteks and Granite.
