yonzariq
So, I got to pick up the latest Fury BLX.
It is my first fast RC in a long time, have been playing with scalers a lot more.
Some photo's and a first impression.
Due to the weather and work I haven't had a chance yet to run it, but did some other work on it
After opening the box, my first thought was that the vehicle looks really good (and huge), love how the stock body looks on it.
First off all, I have replaced the standard TX/RX with my own.
The standard TX/RX is very simple but seems pretty good, big pro is the antenna less TX and RX!
But as I have multiple vehicles I'd like to use one TX for all of them
The radiobox is really nice and sealed, and even though the stock RX is antenna less, they did keep room for an antenna wire and hold-down for an antenna.
My own 2,4GHz set has a pretty long antenna, so I was really happy to see this.
Also I didn't have 4x AA to try the stock TX/RX, my own TX runs on a 2s LiPo.
Servo is the ADS-7M 6kg servo, 6kg is enough, but a bit on the low side, and with 0,14sec on 6v it is neither really fast nor slow, but that shouldn't be too big of an issue, at least it is better than the stock servo on most vehicles.
Big pro is the standard metal gears in the servo, so it should last long enough.
The vehicle was packed good, body had protective plastic on it, some cardboard aorund the a-arms to keep the vehicle in place and prevent moving inside the box..
Really nice to see the body clip retainers as standard.
But what I don't like is that the body post holes are huge compared to the body post itself, in my experience this causes play and fast wear and tear of the body post holes, but we will see how it holds up.
The paintjob looks really good for a stock body though.
The wheels and tires look great, tires feel really sticky but are a bit hard in comparison to what I have run on my other vehicles.
For the non-competitive bashing and driving I do it are probably great tires
Electronics are installed perfect, I switched out the standard deans connector for an EC3 connector which I use on all of my vehicles and Lipo's.
They are rated for 60A continous, and the ESC is 60A max, so that should be fine.
If not I can switch to EC5, they are rated for 120A.
I use standard ROAR sized hardcase 2s packs with interchangeable cables, so that will be an easy fix if I decide to switch to EC5.
But here also comes the problem, the LiPo's fit easily in every vehicle I had so far, but in the Fury, they don't...
They are just a tad too high, so I have removed the piece of foam on the inside of the LiPo tray in the chassis, the one on the lid of the LiPo tray could stay, and now they just fit.
Cut and placed the supplied foam pads on the front and rear of the LiPo to prevent moving and it is completely secure.
Did a small test run with the wheels of the ground, and even on 2s LiPo there appears to be more than enough power on the rear wheels, motor feels really smooth even on low throttle.
Recalibrated the ESc, but did not dive into the options of it yet.
My impressions so far:
+ Price!
+ Paintjob
+ Overall looks
+ Electronics
+ Metal geared servo
- Size of LiPo tray
- Huge body post holes in the body
Will probably run it this weekend and update the thread with experiences
+ Price!
+ Paintjob
+ Overall looks
+ Electronics
- Size of LiPo tray
