godfella691981
- Granite
So tonight I changed the gear in my Granite 3s blx from 15t to 20t. I took the screw out of the bottom, removed the driveshaft, and then when I tried to remove the motor assembly it was REALLY hard to get out, once I got it out I changed the gear and cleaned up inside a little bit. I had a hell of a time putting the motor back in, I lined up the shafts and when I tired to slide it together I couldnt I had to end up smacking it with a screwdriver to get it to go in place. I ran the truck and within 2 minutes the ESC shut down the motor was REALLY hot. The wheels do not spin freely like the did before I don't know what I did but something is in a bind.
Has anyone else had this issue?
