I am running a blx system on 2sGo up 2 teeth on the pinion.
What I would do.
Is this BLX? Running 3s?
I feel like a bigger pinion would just negate what he's trying to accomplish.. I may be wrong i really don't know, would it just have more top speed but be slower trying to get to that top end.. this is a good 2s question, I'm unsure!?If you're running on 2s only, try adding a few teeth to the pinion or even getting a higher KV motor.
I would normally agree. Just that the OP said he wants longer legs in the straights on his pavement track? More speed?2s is prolly the problem, 20t stock.. so you might go down 2 in tooth count for more tourqe.. what u think @SrC
Agree, so do u want it to have more top end or do u need it to be quicker!?I would normally agree. Just that the OP said he wants longer legs in the straights on his pavement track? More speed?
What do you think? It isn't clear what he wants to really do here.
Gear down 2 teeth to see if it helps.I am trying to get up to speeds faster so I guess I want more torque
+1Gear down 2 teeth to see if it helps.
