Just_RC_and_Things
What is the best gearing to run in my Kraton. I don’t want it to over heat and I run and grass and dirt.
Well id keep it stock. If it’s already running hot I’d go down 2 teeth on the pinion.What is the best gearing to run in my Kraton. I don’t want it to over heat and I run and grass and dirt.
What was it like on 4s, worth driving or boring?Ran my V3 on the optional pinion on 6s 6000 HRB's and the motor, centre diff, rear drive shaft and the whole underneath of the chassis was glowing. It was 28 ded outside and ran for 15-20 mins so I def am dropping the pinion back to stock or I may keep it on and drop back to 4s on the warmer days.
Cool I'll give it a try is it a 16t optional, I've got a 15t and a 17tIt was ok not nearly as much raw power but plenty for jumping and bashing at mx tracks ect, only thing I made sure was to have high C discharge batts which make all the difference at 4s and the higher pinion of course.
Hi Cs is a good compromise.It was ok not nearly as much raw power but plenty for jumping and bashing at mx tracks ect, only thing I made sure was to have high C discharge batts which make all the difference at 4s and the higher pinion of course.
