ArrmAh
- Thread starter
- #21
What parts do you lube and what do you use to lube? i'm new RC and asked a guy at the hobby store. He said if my gears were metal i shouldn't have to grease/lube them.I use Simple Green on everything. Body, Frame, Motor parts, Gears, ESC, wiring, even bearings. Then, I spray Windex with amonia on everything as well then, I take my blower I blow off my driveway with and blow all the parts dry( this is where the windix comes in ) then, wipe with paper towel if needed. Then lube all parts needed. Seems to work for me. The Senton has only 7 screws to remove all electrical componets and the body and framework i hose down with the water hose and spray nossel.
