- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
- Thread starter
- #241
Yes for the rigger I'll be running 8s with a custom piano wire drive.Assuming this is for your Rigger you want to build .If you're planing on 8s you'r going to have to go with a 1/4" flex , a piano wire drive or a solid drive shaft.
They have a gear driven transmission off of the output shaft of the turbine which connects to the flex shaft.
Found a guy that makes the whole setup with Delrin inserts in the tube to support the piano wire.
I am going to test the ESC out in my 42" deep vee just for fun and to make sure the ESC is good given their history
