- Granite Grom
- Infraction
- Kraton EXB
- Senton 3s
Would this be a good combo for my k6s mainly would it fit?
and what gearing should I use
Irrc you need the 30mm motor plate to mount that motor. https://www.amainhobbies.com/arrma-...-mount-plate-red-ara320538/p-qqzktaeqncqxactzWould this be a good combo for my k6s mainly would it fit?
That don't fit, that 50 mount fits small motors like the normal one.Irrc you need the 30mm motor plate to mount that motor. https://www.amainhobbies.com/arrma-...-mount-plate-red-ara320538/p-qqzktaeqncqxactz
With the 5687 1100kv you need a new mount, like M3 Germany 5TH SCALE MOTORMOUNT with 30mm https://www.mmm-germany.com/shop/arrma/I’m confused does my kraton 6s v5 need a new motor mount for this or will it work
NoSo i can buy the normal kraton 8s mount and ittl bolt on my k6s
Maybe, i actual don't know.Can i drill into my current to make it work?
I’ll just get the 4985
You’ll be fine on 6s with the Max 6 4985 1650kw combo. I’m running a 21t pinion and a dual fan motor setup on a heavier truck and it’s fine.Are you saying I can’t run 6s because that’s what I’ll be running
I only run 6S as well.Are you saying I can’t run 6s because that’s what I’ll be running
