- The Netherlands, Europe
- BigRock 4x4
- Kraton 6s
- Kraton EXB
- Typhon 6s
Yes that's correct. And the stock one is 208 oz-inch at 7.2 volt. But the esc output is 6 volt in the Kraton so it's even less...
OVERVIEW:
The ADS-15M V2 Servo is designed to give you fast and precise steering. Resilient to the elements and built from hard-wearing materials.
Specification:
Case – Red, Water-proof & dust-proof
Bearing – Dual ball bearing
Connector – ‘Futaba style’ 3 pin connector
Gears – Metal
Spline – 25 Tooth
Dimensions: 40mm x 38mm x 20mm (Excluding mounting tabs), Industry Standard size
Wire length: 300mm
Torque – ADS-15M: 15kg/cm (208oz/inch) at 7.2V
Speed – 0.16 sec/0.14 sec 6V/7.2V
Signal – Analogue
OVERVIEW:
Specification:
Gears – Metal
Spline – 25 Tooth
Wire length: 300mm
Signal – Analogue
