The chassis should touch the floor. That keeps components from over traveling.So I asked in my own thread, but might as well ask here. Does anyone have the issue with the chassis not reaching the ground with these tires? It almost gets there but won't go all the way down.
Unmount the tires from the rims, they are garbage anyway, buy some DE Racing 3.8 truggy rims you can get a set of 4 for about $20( they also have a few dfferent colors to choose from https://www.ebay.com/sch/i.html?_fr...s+Truggy+Wheels+1/8&_sacat=0&LH_BIN=1&_sop=15), tape the inside of the tires and remount them to the DE Racing rims.Tried these today for first time. They balloon up a lot and at least one was terribly unbalanced. Are there any other reasonably cheap options or Any tips to make these better?
Easiest and most simple way I have found to unmount tiresI've seen baking an acetone to demount. What's easiest. Will that fix the out of balance issue ? One front wheel is wobbling and its not loose .
Put a nice 2 inch layer of rocks in the bottom of a 5 gallon bucket, put acetoneiin bucket to just below the rocks, set tires in the bucket on top of rocks, put lid on the bucket. Check on them after 24 hours. Use gloves.I don't understand where the tires go when you say don't sit them in acetone
Sure - no problem! (Yes, I'm a little obsessed with tires and rc's... Lol)
It looks like all the 8th scale tires are sold out at the sites this thread links to
Yeah me too.They have been sold out for a while now. Hoping new stock comes in soon.
Just make sure to not submerge the wheel/tire in acetone or you will have to get new foams. The acetone disolves the super glue, but doesn't destroy it, it more or less thins it out. When you have a foam soaked in the acetone that has desolved the glue, then dry the foam, it gets as hard as a rock when it dries because the entire thing is covered in superglue.Put a nice 2 inch layer of rocks in the bottom of a 5 gallon bucket, put acetoneiin bucket to just below the rocks, set tires in the bucket on top of rocks, put lid on the bucket. Check on them after 24 hours. Use gloves.
I found that out many years ago when replacing 1/10 stadium tires on my first RC.
Now, if I care enough, I bake them, then while hot, I push down on the tire relatively gently while wearing those kevlar "oven mitt gloves". If it doesn't release the glue, then I bake again until it does. If you push too hard on a hot tire, it rips, especially used ones that have small nicks/cuts at the bead from bashing on concrete. BOiling works too, but baking is less of a hassle as you don't end up with scalding water squirting everywhere out of the foams.
When baking, make sure the tires have a pan or tin foil between them and the heat source, or the tires melt.
This acetone method is by far the best to remove tires from rims without destroying tires, rims, or foams.Yeah that's why you put rocks in the bottom of the bucket to set the tires on out of the acetone, the acetone does not actually come into contact with the tire. The fumes from the acetone makes the glue unstick.
Just takes a lot of time and space, especially if your doing MT tires. I never tried it with just the fumes, but doing it the wrong way with the side of the tire actually in the acetone took all night to dissolve one side, then flip it, separate and put it on the other side while at work. Took me almost 4 days to unmount 4 tires.This acetone method is by far the best to remove tires from rims without destroying tires, rims, or foams.
