A friend of mine used round rod but he used 3/8” it’s much smaller than my 1/2” and he bent his. I’ve yet to bend itI tried round aluminum rod from lowes on mine. It's too soft and bends. The square stuff is soft and easy to cut, but doesn't bend like the round stock does.
I used 1/2" aluminum rod as well and mine is still straight as an arrow.A friend of mine used round rod but he used 3/8” it’s much smaller than my 1/2” and he bent his. I’ve yet to bend it
Yeah, mine was 3/8's as well. Even a 1 foot length, I can bend it with my hands pretty easily just using my thumbs.I used 1/2" aluminum rod as well and mine is still straight as an arrow.
How about someone makes a "how to", step by step video? I'm just not comfortable winging it on my own. I can do almost anything given the tools and proper instructions.
Step 1 - go to home depot, buy a bunch of crap you probably don't need.
2 - Grab your Kraton and all you HD crap and spread it out.
3 drink a beer while staring at the truck. occitaionally pick up a piece and stare at it for a while. If anyone asks, say you are "planning"
4 grab a long piece of HD crap, and cut it. Then measure it and find it is too short. Cut it again.
5. start charging batteries, 'cuz you know it is gonna be time to SEND IT soon.
6 - use some zip ties to make the HD stuff sort of work.
7 - SEND IT!
At least, that is how most of my projects work.... LOL
Hey guys,
I will never abuse my Kraton like Kevin did in that video, but I would like to reïnforce my RC cars as much as possible just in case. That's why I doubled up the chassis, installed GKA Customs aluminum upgraded in the essential areas, installed a RPM bumper, and completely reïnforced the body of the Kraton with my custom method. Also some other mods. See this video in which I show all of the mods I did:
Kraton in GKA customs theme and other mods
I hope this helps if anyone out there is also looking to sort of bulletproof their Kraton.
Should still work. The 3/4" makes it so you still have to mess up/remove the center posts in the roll bar thingy.
I did on my outcast. I cut the top part and the X out of it. I think I still have the bottom horizontal bar there.I'm going to have to remove the X's with one inch too, no?
I might go the double chassis route. I'm loving that idea.
Double chassis would add a lot more weight than the T2T brace. Best would be to get a 7075 chassis. Even the, I'd still run the brace to give the towers some strength.
Does the outcast chassis bend easily too? Its shorter so shouldn't be as bad, but I'm wondering if I need to add a tower to tower brace on mine.
They all bend the best thing is the t2t brace. My friends typhoon has a bent chassis pretty much between the 2 chassis braces. He has no t2t braceDoes the outcast chassis bend easily too? Its shorter so shouldn't be as bad, but I'm wondering if I need to add a tower to tower brace on mine.
