Gorilla tape or shoe glue with drywall mesh?
Discussion in 'Paint and Body' started by WTF MIKE, Jul 13, 2018 at 3:00 PM.
  1. WTF MIKE
    WTF MIKE Well-Known Member
    May 16, 2018
    57
    Arrma RC's:
    Outcast
    Need opinions on what method to use to reinforce my bodies. I’m currently using shoe glue with mesh tape. But would like to try something different
  2. ThatDrewGuy
    ThatDrewGuy Premium Member!
    Apr 18, 2018
    113
    62
    Chicago Area
    Arrma RC's:
    Granite, Kraton, Talion, Typhon
    I use the black gorilla tape. Does a darn good job. Actually planning on spraying the inside of a body with Flex Seal. That might be a cool solution!
  3. Swift518
    Swift518 Premium Member!
    Jun 19, 2018
    35
    11
    Wisconsin
    Arrma RC's:
    Kraton
    I just used a spray-on truck bed liner inside my Kraton body . Still flexible but super tough. And easy to apply.
    WTF MIKE and ThatDrewGuy like this.
  4. olds97_lss
    olds97_lss Premium Member!
    Dec 14, 2016
    374
    115
    That stuff adheres to the paint? Did you do anything to the paint to prep it?
  5. Swift518
    Jun 19, 2018
    35
    11
    Wisconsin
    Arrma RC's:
    Kraton
    That stuff sticks to everything but I guess a primer would prob help. Its like ink on your hands if you get sloppy. I washed the inside and dried it out. Then used an alcohol wipe just to make sure it was clean. Sprayed it with 3-4 coats. Could do more i guess if you wanted it thicker.
    Update: Just looked at it after a few runs. The spray doesn't like the side protection stickers that came in the body. Starting to peel off of thise a bit.
    #5 Swift518, Jul 13, 2018 at 6:38 PM
  6. olds97_lss
    Dec 14, 2016
    374
    115
    Any brand in particular?
  7. RxMonkey
    RxMonkey Well-Known Member
    Apr 10, 2018
    104
    146
    Virginia
    Arrma RC's:
    Kraton, Outcast, Senton
    I did the drywall mesh, shoe goo, then bed liner on my outcast and a proline body I just painted. According to another rc forum a guy tested all the different methods on plastic containers to measure durability: this one was the best in his opinion.
    It is incredibly strong. It does take some time to coat the inside with mesh and shoe goo. Prob and hour or so.
    On the outcast body the mesh didn’t stick well at all. The factory finish is very slick and plasticy so it won’t adhere to the inside of the body. I’d suggest masking the outside well (don’t forget the body mount holes like me) and coat with the bedliner paint or anything really. It’ll give the mesh something to stick to. Then take your time a cut pieces of mesh and cover the inside well. I put stripes of shoe goo on about an inch apart and 1/4 thick beads. I did about approx 3x3 inch area at a time. I spread with my finger. The mesh moves around some. After that dries well I coated w bedliner once or twice.
    It’s heavy and super strong. The proline body I did is .060” thick plus reinforced. It’ll be a long time before it’s busted up.
    Edit: here it is- https://www.rctech.net/forum/painti...tection-bashers-long-article-many-photos.html
    #7 RxMonkey, Jul 13, 2018 at 7:47 PM
  8. Drog343
    Drog343 Well-Known Member
    Jun 22, 2018
    7
    7
    Arrma RC's:
    Kraton, Senton
    So far I've tried the mesh / shoe goo and the gorilla tape method, I prefer the mesh / goo cause it seems to be the most resistant to changes in temp. (though I did split one in the cold once), water, etc. (it's meant for repairing shoe soles, etc., so it should stand up to a lot. It can make the body pretty heavy, and it is messy (and stinky) to work with.
  9. Steveoarrma517
    Steveoarrma517 Well-Known Member
    Nov 6, 2016
    256
    203
    Arrma RC's:
    Kraton
    Shoe goo faster method, only need one finger. Stuff easy to get off fingers.Xmaxx experience too.
  10. Piecejointe
    Piecejointe Well-Known Member
    Jul 30, 2017
    200
    84
    Arrma RC's:
    Kraton
    Car bodywork polyester and fiberglass is the next thing I'm going to try.
  • Welcome to Arrma Forum
  • Disclaimer
