- Points
- 418
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Senton 6s
- Talion
- Typhon 6s
- Vorteks
- Voltage
Pulled the monster senton back out of the box that was ready to go to a new home and got a little work done on it. Swapped the 12v fan/bec back out for an aluminum cased 35mm fan on the max6 and no fan on the newly installed 1515. I got lazy and left the 46t spur in on the center diff and dropped a 20t pinion on the 1515. I’ll have to run it at some point to see if I need to go ahead and drop to the 50t spur and drop the pinion a little. On went the hot racing front lower front hinge pin block for the super bash bumper and the fireteam front bumper was installed. I cut the motor off the back of the baja bug body to clear the rear bumper but I may try to find something that sits closer to the tower. I also pulled the senton side plates for noto/outcast to cover a little better. Last bit was to throw the new 1/10 belted mirage tires on it to see how it looked.
I was already painting a red beetle body for a lasernut build so I grabbed a second one to give it a faster cousin. Both bodies came out great!
