Only on the side of the gear (left in your pic).I’m shimming my front diff, should I put 2 shimms in one side or one on each side ?View attachment 82771
Welcome, i wasn't done typing yetOh ok thanks
But it is good to have it tight right? Because if not it may skipOnly on the side of the gear (left in your pic).
You do this to set the mesh between the ring and input gear, so with the shimms you can set the mesh a little tighter if needed.
It's best to do it when dry (no grease), then it's less of a mess and you can feel the gear lash better. You don't want 0 lash. There should be a just a hair of play when you hold the pinion stationary and rock the ring gear back and forth. If you run it tight, it will put excess strain on your bearings, then they will die quickly, which will then likely cause you to fry the ring/pinion before you catch it.But it is good to have it tight right? Because if not it may skip
I just put 1 extra, so there are 2 shimmsIt's best to do it when dry (no grease), then it's less of a mess and you can feel the gear lash better. You don't want 0 lash. There should be a just a hair of play when you hold the pinion stationary and rock the ring gear back and forth. If you run it tight, it will put excess strain on your bearings, then they will die quickly, which will then likely cause you to fry the ring/pinion before you catch it.
