CL-Audio
- Location
- Denver Metro Area, Colorado, USA
- Kraton 6s
- Outcast 6s
Hi guys,
Loving my Kraton. So far I'm stock except for Tekno green and yellow springs, mudguards, T-bone bumpers front and back, and Sweep Road crushers for asphalt. Up next, GKA brace and servo mount and eventual servo upgrade. (God knows which servo to pick, but Savox seems the obvious choice).
My question is, should I be able to pop wheelies stock on 4S or 6S? The reason I ask is I cannot. I can lift the front a bit, but no true wheelies. The lipos I'm using are SMC 6S 4300MAH 40C constant 80C burst and SMC 4S 6500MAH 60C constant 120C burst.
Do I need to change the center diff oil to pop wheelies? Do I need to slap in the optional pinion? Also, if I did slap in the speed pinion does that mean bashing would cause overheating since it explicitly says not for off road use?
Thanks guys, keep bashing!!
