Hello, I have a arrma kraton that just recently had the rear main differential gear strip a few teeth so I took all the differentials apart and shimmed them. Soon after I came across a set of GPM hardened spider gears and sun gears, and a set that comes with the hardened main differential geat and input gear for the front and rear, but they are the Typhon and senton with the 13t input gear and strait cut gears.
Has anyone tried these?
They are fairly expensive, so I would like some input before buying.
Thanks.
Thanks.
