slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
Compare the suspension travel on the 3s rigs vs the suspension travel on the 6s rigs. The 3s rigs have a lot more up and down travel. On full uptravel the dogbone end will probably bind in the drive cup, on full downtravel it could likely fall out. Someone on Facebook was testing this style of axle using a 3D printer and these were the issues he had with his 3D printed ones, they would either bind or fall out.Should be similar to the 6S ones where they pop out occasionally but not very much... or am I missing something that’s a major difference that would cause that?
There is a reason that everyone else's axles use a slider style shaft.
