slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
I saw these also and immediately thought they would be real nice on my new Talion (+ I already have a spare set for my Kraton). GPM shows #45 Harden steel, and state their front & rear CVD's are stronger and have more durability with the thickness increased to 6mm, and much cheaper than stock. I noticed these are .5mm longer than stock, which should be ok. However, on GPM's website, further down it says; " We use a quality light weight high tensile strength aluminum 6061 T6 and then anodized with scratch resistant colors". WHAT??? Either the hardened (harden?) steel or aluminum could be a misprint, but I'm thinking maybe just the front CVD & rear axles are hardened steel & both the dogbones are made of aluminum? Anyways, be careful, if they're aluminum, I doubt these would have any long lasting durability. To make sure before buying any, maybe send them a message?
Like I stated above they most likely put the description for their aluminum parts on that page by accident. It is a new part and again they are Chinese most likely using Google to translate to English.
If you go the www.gpmparts.com website the description is completely different. https://www.gpmparts.com/arrma-krat...d-driveshaft-4pc-set-gpm-mak140rs-p-9852.html and www.gpmracing-parts has a different description as well https://www.gpmracing-parts.com/arr...d-driveshaft-4pc-set-gpm-mak140rs-p-9852.html
