Fat Corgi
So I've been changing a few parts on my V4 Kraton, and one of which was the Steering Assembly kit from GPM. I know a lot of you have issues with their stuff, but for the steering assembly, I thought they'll be fine. What I did have trouble with was making the set fit without rubbing on the front diff housing. The included counter-sunk washers, are too large and foul on the diff case. Easy solution, use different screws and washers. You should also include a single M3 washer between the steering posts and the ackerman plate to lift the plate slightly higher so as not to rub on the diff housing.
It all works fine, but I thought I'd just let people know incase someone else has the same issue in the future.
