Thanks buddyWelcome to AF.
I don't see them on GPMs website. Which makes the part disposable in essence. That's why I don't use them. The inserts wear out and creates slop, then you just need to replace the whole part. I looked at those parts before. Other companies same also when it comes to alloy parts that use inserts for rotating parts. Try contacting GPM. But they are not great with CS. Had an issue with a GPM crawler part tha would not fit, and CS was useless. Maybe you can make them out of Delrin material? Others here may have better information or ideas.
Good luck
Thanks buddyReplace your mounts with stock or one of the upgrades that aren't crap.
