Kraton GPM turnbuckles
Zaiden15
Virginia
  1. Raider
  2. Talion
I bought a set of these awhile back and the ends are soft or so hard they are brittle, however you want to look at it. I had an extra pack of Arrma ends so I cut them to the length of the ones that came on the GPM buckles and threaded them on. Holding up really well so far. Note that only the Arrma ends made for the back have a hole to fit the GPM ones. Ar330230 is the part number for the ends I used.
there not good they ware out and make things wallaby and off balance only if you switch out the ends but then its too long or at least my experience
Yea that's why you cut the Arrma ends to the length of the GPM ones. The turnbuckles and differential case are the two best GPM parts I tried minus the ends. I bought almost all the parts they had for the Kraton and the chassis braces and the front rear hinge holder I could actually tweak by hand. Seems most parts I got were cast aluminum or stamped.
