I don't have permission to view your album...
You can just post them in this thread.I don't see any method to share the album. Tried in Firefox and IE.
The grub screw is to hold the inside part of the shaft on to the diff output shaft.I snapped a few pics and dropped them in an album for those interested. I'm not certain how this forum software manages media so I apologize in advance if they are ridiculously huge. My first impressions are that these things look pretty beefy. Only the slider is aluminum and it shows on the scale. There are no spares included and I'm not certain why there is a grub/set screw in addition to the normal flat head screw that goes into the end of the output shaft. I may get these installed tonight but a test run is not going to happen.
View album 16
Done. If I understood your comments correctly, I think the results are better than initially expected. There are splines where there should be splines. How they hold up is obviously the next big question.
O rings are to stop the aluminum from scratching the black metal I would guess.Well, first off I already like how they use the metal rings to hold the pins in place.
Secondly, I don't like those white o-rings... what are they expecting these to do, act as a bump stop under full compression?
I'd like to see boots on these too... I have a spare set of Hot Racing boots that I'll see if they fit once mine come in.
Post up pics installed!
Something may not be clear in the pictures. These attach exactly like the factory shafts to the diff output with a screw in the end.The grub screw is to hold the inside part of the shaft on to the diff output shaft.
Maybe... I was hoping they weren't treating them as a sort of dust boot, or grease retention.O rings are to stop the aluminum from scratching the black metal I would guess.
Does the aluminum have a threaded hole in it anywhere? Could it be used to lock our one side or the other from telescoping?Something may not be clear in the pictures. These attach exactly like the factory shafts to the diff output with a screw in the end.
What is this hole for then?Something may not be clear in the pictures. These attach exactly like the factory shafts to the diff output with a screw in the end.
I'm not questioning where it goes, just why is is necessary given the factory screw method is used as well.
That I can’t tell you. I didn’t know it had the inner screw for the diff output too. Hard to see that in the pics.I think this setup calls for lube. IMHO
Maybe it's needed to prevent eveventual "wallering out" of the splines by keeping the splines locked.
Is the splined part plastic?
I honestly don’t see the inner screw in any of the pics you posted. Are you sure it’s in there?
