pjmofperk
I’m not sure if this should be multiple threads or not by here she goes:
1) Last couple of times I ran it the reverse function worked only once in a while, most of the time it didn’t work. When it didn’t work, if I didn’t apply brakes the gears kept turning. Is this the ESC, the radio, the transmission?
2) When I land nose down on a jump I often have to reset the ESC to factory settings. Something about this seems to put the ESC out of whack. Thoughts?
3) When I hitting the ramp, it lands on it’s wheels then flips over. Do I need to install shock spacers, use a heavier weight of oil? Suggestions? If I am to install the shock spacers I think that’s done by pulling Down the shock spring then clipping on the.spacer. Am I wrong? I tried to attach a video by can’t from my iPad.
4) The steering servo doesn’t have enough torque to turn the wheels on grass. It only turns a little bit. Paved surfaces, dirt, and gravel are ok. Can anyone recommend an upgraded servo that’s not too hard to install? (I am a noob).
I always appreciate your input and solutions. Thank you in advance for your help.
