bucko1980
For those of you running a 3S in your Granite 3S BLX, what do you have your punch setting at? Mine is at the default 3, but when i hit the trottle all it wants to do is flip over.
??????Loose your slipper a little bit should fix it
Thanks. I found the screw. I bought a spare 4s slipper then JennysRC had them.Bassicly you remove the driveshaft and stick your 2mm hex tool into the hole of the sliper and you will feel it go inside the screw head then you just roll gently the car foward to tight it or backward to loosen it a bit if it doesn't buldge at all i will say dissasemble the motor module and get your slipper clutch assembly on your hand and put a hex driver trought the hole and toght it or loosen
Disagree big time. I’ve owned two (now three) of the 4x4 rigs for a long time now and have a lot of experience with these slippers and driveshafts. If you keep the slipper tight, it’s a matter of time before the u-joints pop. The only way to prevent it is a slightly loose slipper.don't mess with the slipper, it's not what it is made for, instead don't press the throttle all at once, just ease into it, or set the punch to 1 to help you with that.
The slipper is what makes your car slip under heavy throtle making protecting the internals of the car.don't mess with the slipper, it's not what it is made for, instead don't press the throttle all at once, just ease into it, or set the punch to 1 to help you with that.
This makes sense. The slipper is more for protection of the drivetrain in a crash rather than stopping mass acceleration...I didn’t advice to lock the slipper, it should be set appropriately so it protects the drivetrain of course.
what I meant is that it is not intended to be used as “launch control” mechanism, setting the slipper that loose will overheat it. Instead set the punch control to 1, that’s what should be used for the purpose.
