- Kraton 4s
- Outcast 4s
- Outcast EXB
- Talion EXB
And so it begins. Typhon RPM arms and 17mm axles, belted proline trenches, aluminum pivot balls, HR steering setup. Still coming this week is Mamba X and 2400kv motor, steel spur and 17t pinion. Added the GPM tower brace to move the top of the shock out some to keep the same geometry on the shock with the longer arms. Was good to get down to the chassis and clean it up some anyways. Also put 30k diff fluid in rear.
