Granite Granite 4x4 blx pinion spur mesh
GraniteAndy88
So I installed a RR 20t pinion gear seems like the gear mesh is a bit tight...there is some play but not much...are the RR pinions a bit tighter than the aarma brand? Should I just get the adjustible motor mount?
You can either make the stock holes a little larger to give some adjustment or get the adjustable mount.
There is essentially no play at all in one spot while there is a tad bit in other spots.
That is quite common to see runout of the spur.. you can notch on of the holes to gain a touch of play, but realize you have to play happy medium with the runout.. a proper mesh in the tight spot will yeild to much slop in the opposite spot... so only go a touch with the elongated hole...
I left mine as is from the factory and let the spur wear in to concentric.. it doesn't take long for sure...
While the module is out I recommend sealing the lower opening before reinstalling...
I'm not sure I even wanna run a 20t now. I'm thinking 18 or 17..so I'd have to go the adjustible route anyways.
