DriverMcDriveFace
- Granite
Hi all, just got the Granite 4x4 as my first "real" RC car to get into the hobby. Also new to the forums but I can't find any problem that sounds specifically like my current problem.
Problems I describe below happen even if the car is on a block and just trying to make the wheels spin.
My reverse needs some coaxing to work. At a complete standstill maybe half the time it'll reverse the first time I push it to go backwards. I don't hear any sounds, no whine, no motor action, nothing. The light comes on as you expect. Blinking when I'm at less that 100% reverse and solid at 100% reverse input. But nothing.
If I jiggle it from neutral to reverse a couple times reverse kicks in. If I'm going full speed reverse and slam it forward it immediately responds.
If going forward and slam it into reverse it will never go into reverse. It acts like I put it into neutral except for the fact the lights will come on.
I've tried messing with the endpoints (sidebar question: I can use the endpoints to limit the top speeds so I can let my son drive it and not worry about him going 30mph into a wall right?)
***Although I haven't tried setting the endpoint at slow speeds in forward and backward yet and testing with that. will try tonight if someone thinks that will help isolate the issue.
Messed with the throttle trim where I would find the spot just below it sending in reverse or forward without causing the light to come on. No discernible difference in reverse responsiveness.
I loosened up the slipper clutch a bit thinking that maybe it was too tight. Maybe an inch or two in tire rotation when using the provided tool, seems to have made a small difference and the car doesn't seem as 'shocked' if I throw on the throttle to max.
I'm just not getting it.
My only thought from reading on random forums is leading me to think that either the ESC has a flaw OR the motor requires more voltage to go in reverse than forward and the provided battery pack isn't hitting the required voltage right away even when fully charged and I need to get a 2s Lipo for a more consistent charge.
That's my thoughts, observations, etc... but I'm still a super noob at this and hoping someone more experienced can help me out with this.
