Granite a arms
Bigdog3890
  2. Senton 6s
  3. Notorious
Does anyone know if these a arms for granite fit on the 4x4 blx version ?
I would not use aluminum a arms. You need the flexibility of the plastic ones. That brand is cheap crap too. Might as well just burn the cash and get it over with.
Those are the correct ones, they fit the Granite/Senton/Big Rock. Yes upgrading to aluminum will end up causing the pin to rip out of the bulkhead instead of breaking the a-arm but if you don't bash and you like the look then I would go for it.
If it were me I would upgrade the Steering Block and C-Hubs and keep the stock A-Arms. I would much rather replace the stock a-arms for $8 and take 10 minutes to replace one than have to take it all apart to change the entire bulkhead.
