- Thread starter
- #21
Even if you don't like soldering, consider changing your battery plugs to EC5 yourself if EC5 lipos are more expensive. EC5 is really easy to solder. The metal connectors come separated from the plastic part and have little cups at the end. You can put the soldering tin in the cup, heat it up with a lighter and push in the cable. No soldering iron required.
Cheers for the tip, I may try this, as no doubt I'll end up wanting more batterys at some point or 3s, thanks, guess there's some YouTube vids in this
