Banging_Gears
- Kraton 6s
Hello, I've had this Granite BLX 3S for a few months, I've removed the Power Module once before to clean it, grease gears.
Couple months later, I want to do it again and it's stuck! I can bend each side out, but it looks like the output shaft is stuck to the rear diff input shaft, or something like that as that's the only part that doesn't bend.
I've pushed both sides at the same time to the point I hear it starting to crack, but still the center part will not budge. The sides do move a couple mm, but nothing at the center.
Support is a joke, they say I am doing it wrong, and will only send me a video how to remove it or send it in, which I have to pay for. How about that warranty? What does the warranty cover again?
Replacement motor mounts are not available, so i'm pretty much hosed?
Video of the problem here:
