Zoomfast23
Hi, can anyone help me with how to fix and keep this from popping out or do I have to buy a new one didnt have this truck a month and after 4 runs in grass this happened twice. Any suggestion I would really appreciate it.
Thank youSlipper is most likely to tight.. that shaft is beat.. once they pop it will continue to pop.. replace it or call horizon and warranty it...?
One question how do I warranty it i bout it off Amazon?Slipper is most likely to tight.. that shaft is beat.. once they pop it will continue to pop.. replace it or call horizon and warranty it...?
Thank you
Lol I did just that and it worked it haven't popped out yet I've jumped multiple times and its still attached but they did send me a new set thanks for all the advice.Agree with the others that say the slipper clutch is too probably tight.
While you are waiting for a new part, snap it back together. Then use a heat gun or a rework station to soften the plastic and use pliers to reshape it.
???Lol I did just that and it worked it haven't popped out yet I've jumped multiple times and its still attached but they did send me a new set thanks for all the advice.
