I put the m2c adapters on my wife's Granite and the wheel nuts barely grab any threads, they're about half off the hexes. Anyone else have this issue. Using Proline Badlands.
But does your wheel nuts tighten all the way or hang off a bit? Because the problem I'm having is they won't. They're too short with the wheels on.I run these on my Bigrock with the MX 28s without any issues. Only thing I've had happen is the center barrel nut came off once so make sure to use loctite on them.
They aren't all the way on I agree they do hang off a little bit. But with some loctite and tightened down they haven't came off or gave me any problems.But does your wheel nuts tighten all the way or hang off a bit? Because the problem I'm having is they won't. They're too short with the wheels on.
Yep, thank you. Thought I was having one of those idiot moments where I forget to do something really obvious.They aren't all the way on I agree they do hang off a little bit. But with some loctite and tightened down they haven't came off or gave me any problems. View attachment 175977
